ION Ecoder wheels and MAC 700's
I have rented 4 MAC 700 profiles for a production I am working on. We just got our ION last summer so I am still learning, but I have run into an issue. When I am in the image screen or even the focus screen for movers and try to use the function where you hold down the encoder and jump to next or mode, etc it will sometimes cause the 700's to go into what appears to be a pre-programmed effect and douse almost completely out. I then have to home the fixtures to get control back. Am I missing something?
  • You may be tripping over sending inadvertent magic settings to the fixture, a combination of DMX address and value that turn on macros, provide lamp control, and the like.
    I am not familiar with the MAC700 but I know the MAC250 will do a fixture reset, lamp off, and some other weirdnesses when certain values are sent to certain channels particularly when playing with the shutter.
    Check the Fixture Release Notes that ship with the offline client (C:\Program Files\ETC\Eos\Documentation\FixtureReleaseNotes.pdf) for clues about enabling/disabling DMX remote control of fixture settings.
    Also check the user manual for the fixture (http://martin.com) to understand the DMX map.
  • I too have experienced this problem with 700s (although I suspect it may not be limited to this fixture?)
    It happens if you select a channel, hit "form" (or otherwise) and then use a next/last function on an encoder, as pawpaw said in his post.
    The desk seems to be sending the "next" command to the overall form category (or possibly even the whole unit) so every single attribute advances by one step - placing a gobo in, strobing, iris, animation, prism...... giving the wierd effect you have seen.
    Perhaps this situation has been fixed in a more recent software version though - mine is a little old. It can be avoided by pressing enter after selecting channels so that you aren't calling up commands when you hit Form/Image etc but it's still odd that it doesn't realise you want to just "Next" the one feature.
    Cheers!
    Leo
  • What software release are you all working with?
    a
  • I have also experienced this with a vl1000. But in my case its when I fumble and put beam into the command line type a number (i.e. beam 200) and hit enter, then it closes shutters and does all sorts of fun stuff. Don't REALLY know if that bit of info is helpful to your case, just thought i'd mention.
  • It happens in the latest release for me.
  • Hi everyone.  I'm assuming all (or at least most) of you are using ION, and this problem is occuring when changing encoder pages, specifically beam pages?
    When you press one of the encoder pages, the LCD screen re-populates to the selected page of encoders (as we all expect).  There is a nifty trick that you may or may not be aware of where you can use the encoder keys to post their respective catagory to the command line.  ie, pressing the encoder [focus] button will post "focus" to the command line, [colour] will post colour, and [image][form] or [shutter] will post "beam" to the command line.
    The advantage of this is it saves having to use the mouse, or reach that extra bit further to the touch screens to select focus, colour, or beam and is the equivalent to the catagory hard keys on the eos which are located just above the key pad, at the base of the right hand touch screen.
    This is also the case with the encoders themselves.  Say you want to send the iris home and one of the encoders infront of you is posted to the iris, a short press and release will post [iris] to the command line.  Again, I find myself using this alot to save having to reach to the touchscreen or reach for the mouse.
    There are two ways to use this feature.  Firstly, having a channel posted to an unterminated command line, and then tapping and encoder, or using an encoder paging key will post the parameter or category to the cmd line.  Alternatively, having a channel selected and pressing the paging key twice will post the category to the cmd line.
    While this is a handy feature, it can sometimes trip you up (well... it trips me up from time to time).  Say you have a Mac700 selected and want to change the animation wheel, and you currently have pan and tilt on the encoder.  You will press the [image] paging key once and probably get gobo or some such, and so will press the button again.  This WILL post [beam] to the command line.  Same goes if you accidently tap an encoder.
    I have found I will press [image] or [form] and especially [shutter] several times to get to the page I'm after and will have posted [beam] to the command line without noticing.  I might play with the shutters, or change the iris and then the LD will say "na, don't like that. Can you open the iris up please".  I'll have iris on the encoder so will press the encoder and then press the home key.  Because i have unknowingly posted [beam] to the command line i will not only clear the iris, but also the gobo, the shutters and any other beam data. (yay for undo).  After I do it once or twice, I pay more attention to what's on the command line, especially after playing with encoders
    Could this behavior be the cause of your problems?
    Cheers.  BFJ
  • Good input Brent.  An FYI about 1.5.  On Ion, if you use the encoder to access different functions, or if you use the paging keys, the function posts to the command line (this is done so that if you were trying to access a parameter or parameter category for timing or manual control via the command line... you don't have to use the CIA tiles....  If you move the encoder, or access any of the functions provided by the action, we will clear the parameter from the command line.  So you won't get tripped up so much by having "dangling" commands.    That should help a lot.
    a
    [edited by: Anne Valentino at 7:29 AM (GMT -6) on Tue, Feb 24 2009]
  • It is indeed this feature which is causing the behaviour.
    The problem is that holding in an encoder to get "Home" "Mode" "Last" "Next" etc and then pressing such a key was affecting the overall Beam category rather than just the parameter on the encoder. I think it would be fair to assume that a user holding down the iris encoder would want to only affect the iris with a "Next" rather than the whole category?
    Cheers,
    Leo
  • Leo, this action should be parameter specific ... not on the entire category.  Don't have a way to check at the moment, but will as soon as I can.
    a
  • Just Fyi, I had this same problem on a pair of Martin Mac 550 on a recent show.  I know that Encoder page editing is on the list for the software developers, but for some reason the two color wheels on the Mac 550 are on different pages.  So when I push the encoder wheel down and use "next" or "last" to scroll the color wheels to index colors, the board puts both coor wheels into a "spin" command (rather than the continuous that I was in and hoping to still use).  It takes many keystrokes to correct this (This is my first show on the Ion and I had not yet learned much about the "undo" command) as I have to toggle between all 4 color pages to get to both color wheels.  Here's hoping for a fix and encoder page editing in 1.5
    -Adam
