Importing ASCII Softpatch - Ion
I am wondering what the proper procedure is for importing just a softpatch. The current documentation says that import Lightwright supports either .txt or .asc. I am used to exporting to .asc as that is how I do it with Expression. When I go to look for the .asc file on my usb drive (in the root directory), it does not show up. I can import the patch as an entire show with the .asc, but I don't want it to overwrite the show, just the patch. The documentation talks about an advanced option when importing, but I think that is from previous versions. The only workaround I can see right now, is importing the patch, then re-opening the show with everything but the patch. Am I missing something?
