Bunch of Feature Requests - January 2020
Bunch of feature requests
I am an EOS programmer, and I have compiled a list of some features I've wanted for awhile, and updated them from the last time I posted them.  I put them in categories but going thru this from the last time I posted, I realize they are mostly meaningless and I apologize for that.
Quick Quality of Life fixes:
Record Target (preset/focus palette/etc) Next should call the next empty target. Right now if I have a preset 999 but nothing between preset 1-998 recording preset next will put 1000 on the command line.
Recording a preset has default options. Such as plus fx, I hate to press this every time I record a preset if I am recording a bunch of presets.
Multiple Fan presses will cycle thru various fans and will auto terminate (i.e. fan fan = fan center, fan fan fan = fan reverse) kind of like how "time" works. On Gio and Ion having to press fan, hold softkey 1 enter is a little cumbersome. I have it assigned to a macro most of the time but I'd like the default to be simpler.
Highlight auto terminates (or double pressing highlight terminates the command). (I realize this is now shift hightlight, but I wish it were the opposite and that shift highlight left it unterminated)
Mark mark cycles thru mark states (mark mark = mark earliest)
Cuelists available in Direct Selects (serisouly, multiple cue list organization is atrocious right now)
Recording Snapshots default to current screen instead of all screens (or better yet, settable defaults. As anyone would, I hate recording a bunch of snapshots and having to click the same options every time.)
Help for about and shift should contain all of the quick shortcuts now that there are so many.
Displays should always bring up the file menu in the CIA. It doesn't if About is toggled on.
Direct Selects can have an image pressed upon them. I know, just make magic sheets but it would just remove one degree of difficulty.
Medium Level Improvements:
Ability to save a display layout or size of a particular frame aside from snapshots. Say I have a two column set and I want to add a column, well all my columns will resize and I want the right most column to match my two column setup, there is no way to match that size, it's just a visual approximation.
Ability to lock softkeys on for Gio and consoles by quickly double pressing MoreSK, or shift moreSK or something.
Pan Tilt xy axis as a magic sheet object for effect visualization
A way to visualize color scan/spin mode in magic sheet objects, even if it's just an asterisk, something noticable. Yes it's avoidable but I've accidentally screwed myself by having one color wheel on spin while the magic sheet shows the active color from colorwheel 1
Current gobo or prism as a magic sheet object display field, like link color or intensity
Blind magic sheet shows color of fixtures and effects like live mode does
Blind or live is storable in snapshots
Hitting blind or live or shift blind or live just changes the state without changing displays (such as right now live table shifts to blind table in a different flexi state)
Programming wing and Ion Xe faders assignable to submasters (or something useful)
Ability to get rid of tab 1 and 2 (psd and live table). This is super important. I literally don't understand why we cant have these two tabs closable. It's a pain to have to shuffle them somewhere when I am working off a magic sheets or on direct selects.
Ability to press live and not have Tab 1 and 2 rise to the top.
A way to remove channel data from live from a cue. I feel like this one is already possible and I just don't know what it is, I always go into blind spreadsheet
Ability to tap out follows (i.e. the console will automatically measure the time between GO's and auto record that into the follow time of a cue)
More configurations of displays (i.e. a stack of 4, or completely customizable (add row, add column)
Ability to reorder encoder positions. Instead of having red green blue white on one page, I might want red green blue Amber. The move to command code be used.
Direct select is their own category on the display select screen. So that opening a new display or frame it's just one single click to the DS you want.
Shift-effect it would be nice if I could see the XY pan Tilt (or any parameter) axis while adjusting parameters. Adjusting the rate eliminates the channel selection from ML controls so you cant see your adjustments live until you reselect the channels.
Effects adjusted live should be able to be "saved as new effect"
Some kind of visual representation of show data. I was copying fixtures on a show last month trying to make life easy for myself, and I screwed up trying to copy show data around. What I personally would like would be the following:
soft key for save fixture show data. A column is there that puts a bold 101 next to channel 101. Then if I copy fixture plus data to channel 111, I'll see that 111 is now filled in, but with the show data for channel 101. If I copy show data to 201-208, they all still display show data for channel 101. Pressing the softkey for "save fixture show data" overwrites this and now 111 will display show data for 111.
Major New Features:
New tabs by double pressing of a key (preset preset for example) can be a pop-up instead being a permanent tab for a quick edit, which is mostly what I use them for. Like the pop-up magic sheet and snapshots. Preferably not in the CIA
It would be nice if offset was a hard key, maybe instead of path. Offset offset cycles thru offset states. In lieu of a hardkey replacement, or having it replace key 821, it would be nice if double pressing group would cycle thru offset states.
Having encoders be snapshottable (such as pan and tilt always being encoder 1+2) would be great, and then other stuff gets assigned to encoder 3 and 4.
Would love if the CIA went away entirely. File and setup could be their own tabs instead of having to clumsily scroll thru the menu. I spend far too much time collapsing certain menus to find the showfile I'm looking for under one of many menus (merge, open, save as) and also setup is buried beneath all of that.
Best,
-Michael Kozachenko
  • Michael, you're living in the future! My +1s below:
    As someone who doesn't always get the luxury of a touchscreen, these multiple presses look great to me.
    Of course, for offset a lot of the options can be cumulative, so maybe there would have to be a syntax like Offset Offset would start to cycle the direction options, and then after a slash, it would cycle through the grouping options, and then after another slash it would cycle through the spacing options. So to get to Odd it would be Offset / / / Offset, and to do Mirror in, Chan Per Group 5, Even, it would be Offset Offset / Offset 5 / Offset Offset...it looks like a lot of button presses, but with the menu visible I think it would be more intuitive than it looks.
    Run into things like this all the time. Not sure what the best solution is, but I do have some Snapshots that work like popups from a one frame layout to a two frame layout, or a three frame layout to a four frame layout, and it would be nice to be able to be as picky about that as I'm able to be in magic sheets.
    This is really really interesting. It does get repetitive to have to keep reselecting the same channels over and over again to repopulate the ML controls field. Imagine having a Channel Parameter as a target for a magic sheet object, so that you can have a permanent view of that parameter while it changes, and watch six dots move on six different axis displays instead of all of them on the same display, and only when you have them all selected. Having encoder wheels/Pan Tilt xy axis/color pickers as magic sheet objects would be very powerful.
    Also very interesting. Linking color and intensity to an object is very intuitive, and does a lot to streamline my workflow. Working with image parameters in the same capacity holds a lot of potential. Along this vein, since a magic sheet object can link color to the gel field in the patch database, would it be possible to add a gobo field to the patch database, so that a Link to Gobo option for a magic sheet object could work for a conventional fixture as well as an intelligent fixture, given that the user has uploaded the relevant media?
    I'd also love this as an option. Michael, if you aren't aware, you can set magic sheets to "Channel Display" to make them stay on top when you shift from live to blind (Magic Sheet≥Edit tab>Settings>Display Behavior), but as far as I'm aware, this is only an option for magic sheets, and not, for example, direct selects.
    +1
    I like this idea. A "Configure" or "Classic" option to open a DS tab in its current default state, and the rest of the target types laid out in the display menu.
    I imagine that a lot will change with the release of 3.0 and Augment3d, and at this season of its anticipation, I am especially grateful that the Eos family dev team at ETC continues to put out extremely high quality and free updates to the software, and that ETC as a company keeps looking to its user base as a source of innovation and inspiration. Thank you all so much, and have a happy new year!
  • Each feature request deserves its own thread. That way people can "like" individual requests and it also keeps it organized. There are a lot of great suggestions but a few I don't like.
  • Also very interesting. Linking color and intensity to an object is very intuitive, and does a lot to streamline my workflow. Working with image parameters in the same capacity holds a lot of potential. Along this vein, since a magic sheet object can link color to the gel field in the patch database, would it be possible to add a gobo field to the patch database, so that a Link to Gobo option for a magic sheet object could work for a conventional fixture as well as an intelligent fixture, given that the user has uploaded the relevant media?
    Just found the Augment3d feature video that says that this is coming: https://www.youtube.com/watch?v=pYMKTEEDuBI. It's going to be a giant, giant update.
  • I love the idea of breaking the file browser into its own tab, but it is very useful to have other interface elements appear in the CIA contextually eg. effect status, encoder displays, etc.
  • There's 20+ feature requests here, so I don't feel like posting a thread per is wise. I might pick my favorites and do a couple threads.
