It's Dance Recital Season again. We all know how this works- 30 or 40 songs. Each song gets a cue or two. If you see a rehearsal, its not in show order. Many schools do several shows that are nearly indentical but in a different order. I do these in Cue Only mode.
I do all my fades manually using several layered Inhibitives and advance the cues while dark. When preparing for the next and subsequent shows, it is neccessary to rearrange the cue order. [The Copy To/Move To is GREAT and easy! ] About half the cues have an Effect or two or five running. [Putting Effects into some cues and not in others is AWESOME and easy! ] However, once you start moving cues, the rules of Cue Only no longer apply to the Effects. My guess is that there is a Stop Effect instruction in cues that when moved, allows running Effects to track forward (undesirably).
With no time between shows to actually look at each cue on stage, this did lead to a lot of frantic Stopping of Effects Live, and much clueless scrutiny of whether so and so channels really ought to be in so and so Effect in upcoming cues.
Questions: Can there be a true Cue Only mode? What do I need to do in order to rearrange a cue list without this happening? Would putting a Block on every cue globally before moving anything do it?
Thanks, B
[edited by: BSmith at 11:34 AM (GMT -6) on Mon, May 18 2009]
