Hello!
I've recently discovered a few bugs when using Robe Spot 575 XT on Augment3d.
1. It seems to always have the 3-facet prism engaged, no matter what the parameters of the fixture are set to.
2. If you activate the continuous wheel spin on Color Wheel 1, it will not deactivate until Eos is restarted.
This has only been tested on Augment3d, not sure if this behavior also affects the actual fixtures.
I've tried it on both Mac and Windows (10) and had the same results (Nomad Eos v3.0.2.6)
