Ion unparks upon being turned on
I was operating an Ion at a church over the weekend, and before I left, I saved my show, and turned off like normal. Everything turned off like it should, and after a few minutes the non-dims shut off as well.
Today, the console was turned on (by the production manager, as I do not attend this church, or live near it), and it loaded fine, except that none of the moving lights came on. The dimmer racks have non-dim modules, which are parked by the console, but nothing was parked. It is the same exact show that the console loaded that it was last used with (by me). Is this a software bug?
The console has had many quirks before (the LCD's didnt turn on, it would crash at booting, have jumbled LCD (external) screens). There is a UNISON system that controls work lights, which are also on a non-dim circuit. The lighting console has access to these as well; the Ion is running Net2.
Any thoughts on why the console would load, but with unparked channels when it has loaded fine times before with those channels parked at full?
I had the guy go to the dimmer room, and note all the non-dims, and go repark them. Any ideas are greatly appreciated, I plan to download the new software (to floppy... I presume?) and load it into the Ion next time I am there.
There's also problems with the Unison system... but that's for another day once we figure this Ion deal out.
The desk is about a year old, is one of the first runs, and has had problems since the beginning; they're just getting worse unfortunately.
  • I can't help with your issue, although I can say that that should not happen.  I have channels parked and they always come on with the board. I know there were some changes in whether or not parked channels get stored with a show file, but I can't remember what the behavior currently is. Do you know what software version the board was running?
    As for updating the software that is done by using a usb flash drive.
  • Hi guys.  The park buffer is maintained through power off/on and loading new show files.  (We have had discussions about including the park buffer in the show file store/open, but haven't yet made that change.
    Can you email me the log files from the site (or ask someone else to do it if you are no longer there), along with a date/time that the park buffer cleared??
    Also, I saw your post on Lightnetwork, where you indicate the site is running an extremely old version of software.  Do you happen to recall what version that was???
    Thanks much!
    a
    [edited by: Anne Valentino at 8:58 AM (GMT -6) on Tue, Dec 22 2009]
  • Not sure how to get the log files, the console turned off in perfect state, and turned on in a state which caused irritation, and a few grumpy calls to me. If the log files are stored, I can definitely call ETC next time I am there and get a step-by-step on how to get this.
    It is a first-run of the console, so whatever the first release of software is that was out when the desk first came available.
    The park/unpark problem happens at random times. Every show was copied from a main show, which had those channels parked; but sometimes the console doesn't boot properly, or boots with unparked channels.
    When updating software, can I jump to the latest, or do I need to go through all the updates in order?
  • rslx
    Two things.
    First, you should register your console with MyETC.  This will give you email notifications when new software is released.
    Second, you should update the software of your desk.  There have been many improvements to the console since the initial release.
    As for retriving the log file.  The files are stored on the desk.  You will not be able to access them from the console software.  You will need to exit the console.  This will bring you to a menu page we call the Shell.  Click on settings.  Next click on maintence.  There will be a tab called save logs.  Insert a usb key into the console, count to 5 and click on this tab.  This will save the log files to your usb key.
    If there are any questions please contact support at 800.688.4116,
    Hope this helps.
    P-
  • Thanks Peter...
    You can update directly from their current build to the latest release.  There is no need to install each release in sequence.
    Thanks!!
    A
  • I'll make sure that it gets registered, if it's not already.
    Do I need to go through all the software updates, or can I jump to the latest release?
  • You can update directly from their current build to the latest release.  There is no need to install each release in sequence.
    a
  • So the Ion was updated with the latest software, and then again this past sunday turned on with no parked channels. There has to be something wrong now. Nobody is advanced enough to write a macro, or even accidentally write a macro - they had to call me to find out how to even park a channel. It also decided to crash upon being turned off - the monitors had overlapping menus, and the screens on the console had several horizontal lines showing. They had to unplug it to turn it off.
    Their ETC rep (who also did the install) isn't the most helpful with the problem, it's usually him telling them to update the software and take care of it themselves.
    Is there anything that could be done with this thing? It's a PITA for them, and a really big pain, and a serious downer to use that console.
    I told them how to park the channels from their CEM+ dimmers, and they are doing so - one problem partially solved.
    Any ideas on why this thing crashes, or still unparks stuff? Maybe it's a DOB that nobody decided to send back?
  • Please ask them to contact tech support, and describe the problem.
    a
