Ion and I-Cues
Hi
Ion 1.8.0
I've just received my first DMX devices: rosco I-cue and a dmx iris.  Thanks to the ETC phone tech, I modified a Utility personality in 5 minutes for the iris.
For the I-cue, I rigged it perpendicular to the centre line pointing DS, and all works fine: Pan sweeps across stage, Tilt moves up/down stage. (patched as 16bit)
Not knowing the final position of the instrument in the room, I tried to invert Pan and Tilt (as if it was pointing upstage).  the buttons in the Patch Attributes screen wouldn't latch on.  their command would appear in the command line.
The Swap command worked: pan moved it Up Down, and tilt went across stage (but the scaling of how far it went per click seemed way off).
Do I need to invert Pan/Tilt on the I-Cue rather than the console?
Any general advice with these toy. . . . tools?
If I do point it across the room, and swap pan/tilt, can I correct the scaling?  1 direction sweeps 58deg, 1 direction sweeps 200+ deg.
Thanks.
