referenced effect from preset inside several cues
hello,
using eos 3.2.7 build 18
i have several cues using the same focus effect.
so i have recorded a preset containing this effect with "plus fx".
i am referencing this preset in several cues.
the result is fine, the effect is the same one on each cue.
and then, i am changing the effect size inside the preset.
the cues are not following this change from the preset.
i need to edit all my cues to ask the channels to use the same preset again...
is it a bug or a normal behavior or is there a workaround ?
