Hi
When running my showfile on Nomad, i have very slow response, colour wheel spinning, tablad s not moving, scrolling impossible..
What could be the cause? running on Macbook pro with Sonoma 14.4.1
thanks for help! Anne
Hi
I would just like to add that i downloaded the latest Eos software and updated my macbook. When i load older show files the nomad software runs fine. But when i upload the showfile we are now working on on a Gio and an Ion, it is unworkable in Nomad. Everyhing freezes and eventually just stops working completely..
thanks for any tips to fix it? What could be causing this?
Running your show file on MacBookPro 16``(2019) Sonoma 14.5 and can't see any problem.
Maybe you update your Macbook (which type and year? EOS version?) and reinstall your nomad software,
it should the same version, language and library you have on the consoles. Last EOS version is 3.2.8
The problems only start really as soon as i try to go through the cues with space bar. Then the colour wheel starts spinning. Could you please try this also? thanks
I tried this with no problem. But I need some more infos about your system.
Macbook from 2021 with Sonoma 14.5
eos 3.2.8.25
fixture library 3.2.7.18
I tried it now again, the software basically crashes, it's impossible to work in the show file.. My plan was to prepare the touring shows.
Did you reinstall your Nomad software? Which kind of MacBook? Air/Pro, Intel / M1/2
yes i did. It is an M1 macbook Pro. The strange thing is that when i open an older different showfile everything runs perfectly. The problems in the Sancta showfile only start as soon as i try to run cues. Then everything starts to freeze.
Ich habe das Showfile auf mein MacBookPro mit M1 geöffnet und habe keinerlei Probleme.
Schau mal in der Aktivitätsanzeige (im Order Programme / Dienstprogramme) ob evtl. ein Hintergrund Prozess läuft der das System blockiert. Sonst ruf mal den TechService an, vielleicht haben die das Problem schon mal gehabt und gelöst.
Vielleicht hilft es auch das System zurückzusetzen unter Browser/Clear und die Vorstellung erneut einzuladen.
Even if it is probably something with that specific Showfile.
Have you had a look in the Shell if you only use 1 Monitor?
I once had a case where that occupied a lot of resources.
Is this still happening? I would first open up Activity Monitor to see what your CPU, RAM, and Disk usages are at. That may give a clue.
unfortunately still happening. Only with this showfile. Another funny detail: the file runs smoothly until i press a cue. Only when the cues start running everything crashes. There must be something in this particular file but i can not work it out. On other computers the showfile does run fine.. With other showfiles my Nomad runs fine...
Please report the Activity Monitor behavior before and after. Sounds like a bug. Also record any crash reports that may come up.
This sounds possibly like a recursive memory leak. Anne , by "everything crashes" do you mean "Nomad disappears completely in the blink of an eye and I need to restart it because it completely disappeared" or do you mean "it gets really slow and the spinning rainbow wheel of death comes and won't go away and when I press buttons nothing happens for a while"?
