Partitions are not honored while using the FLASH softkey or the Shift Shortcut Keys. Is this expected behavior?
While utilizing a User with a limited Partition of channels, I can still FLASH channels outside of the partition.
Is this expected behavior?  The idea is to be prepping on one stage without affecting the other.
One of our Users accidentally recorded channels outside of their partition into a Group and then FLASH-ed the GROUP; this caused the channels on the working/active Stage to be flashed as well--even though the channels are outside of the User's Partition.
Grabbing the same group and using standard levels like "@ 40" honors the Partition and has no effect on the channels outside the Partition.
Thanks for you help,
Matthew
3.3.5 b89
EOS @5's
No Processors involved with Expansion Processing disabled.
(recreated OFFLINE as well)
  • I'd say it is a BUG.  Perhaps I've explained it poorly.  Attached is a video showing that FLASH-ing the channel does not honor the Partition.  (Using [Shift] [Full] in this video, but using the {Flash} soft key also ignores the Partition.
  • This is currently written up as
    [EOS-49665]
    Flash on a single selected channel, Does Not Respect Partition State
  • Thanks for the info!  However, the write up should change to include "any selected channel(s)".  See attached video:
  • I can't reproduce this. Please send your showfile to eos(dot)moderator(at)etcconnect(dot)com.
  • I could reproduce the single channel flash outside a partition too.
    But the multiple…You did select those channels via a group, right?
    Because getting multiple channels (via a [through] or [+] outside the partition respects the partition.
    And you cannot record a group with excluded channels from partition.
    But I could reproduce your shown behavior with groups which were recorded prior to the set user partition.
  • Yes! A group is involved.
    1) Copy and paste a “Group” button on a Magic Sheet
    2) That duplicate button has channels outside of the partition.
    3) Select Group Button that has channels outside of the User’s partition.
    4) Flash group and the partition is not honored.
    OR:
    Grab a selection of channels via the Magic Sheet objects that are outside of the partition and FLASH them. The partition is not honored.
    Maybe this multiple channel problem is tied to Magic Sheet channel/group selection.
  • Thank you, Group was the key. It's not about selection from a Magic Sheet.
    I updated the previously mentioned bug report.
  • Thanks for patiently working through it.  Using a Group is essential for the Partition to not be honored in my scenario.  Selection of multiple channels via a Magic Sheet drag does honor the Partition.
