Need help setting up a new WAP for iRFR
I've got a Netgear WPN802 v2  wireless access point.
I have it connected to a 3Comm ethernet switch.  It was finally working for a few days.  But I keep getting a Windows error on the Ion saying "IP Address Conflict with another device on the system" , but the iRFR would still work.
Today it will not connect.
I have the WAP set to get it's DHCP client turned on (so it gets it's info from the Ion)
the DHCP option is turned on, on the Ion.  192.168.0.1  is the IP I'm using on the iPod and set in the Ion.
I'm attaching the setup page from the Netgear WPN802v2
I need help setting this up properly.  I'd like to have it set to a static IP but don't know how to make it work.
  • When you say
    "the DHCP option is turned on, on the Ion.  192.168.0.1  is the IP I'm using on the iPod and set in the Ion."
    Are you saying that you have both the Ion and the iPod Touch / iPhone *both* set with that same IP address?  If so, that is your issue.
    When you say that
    "DHCP is turned on, on the Ion",
    do you mean that it is a DHCP client, or the DHCP address server for the network?
  • Sorry, I hit send, too soon...
    So basically, if you want a static network (assuming you can give a static address to your switch and your WAP...
    It should go someting like this:
    (I'm using the 10.101.xxx.xxx scheme that ETC uses...because they have their devices grouped out and I mostly have it memorized...)
    So...to make your network static:
    You need to turn off the DHCP address server device that you have on the network, and "turn off" the client services on each DHCP enabled client. (usually it is a choice to toggle between dynamic and static)...
    Ion- 10.101.90.101
    Switch- 10.101.1.1
    WAP- 10.101.2.1
    iPod- 10.101.125.101
    PC- if there is one on the system- 10.101.1.101
    Any client devices (ie  Net3 Gateways, client laptops, etc) 10.101.50.101 (and up)
    I'm operating off the assumption that you understand the Subnet Mask and Gateway addressing, and how to edit these properties in each of your devices.
    Does this make sense?  ETC has a handy little chart for static IP addresses that they have created on the 10.101 private network...and if I can find it later, I'll post it.  I may not be remembering the same numbers that they have for each device, but no matter, this will work, as well.  You certainly can use the 192.168 scheme, as well...
    Please note that this means whenever you need to plug a new device in, it will need to have a static IP manually assigned to it.
    Does this help at all?
    Abby
  • Ok, thankyou for your directions!!
    I turned of Network Services on the ION.  I kept the IP address within the range of the Netgear WAP that I'm using 192.168.x.x
    The ION is set to a static IP of 192.168.90.101
    Subnet Mask is 255.255.255.0
    Default Gateway is 192.168.0.232
    WAP is set to 192.168.0.231
    Subnet mask 255.255.255.0
    iPod WiFi setting is set to a static IP of 192.168.125.101
    Then the ETC app is set for 192.168.90.101
    It work wonderfully now.  Thanks for your tips!
  • This isn't a good scheme you've gone with, and you are storing up trouble for yourself in the future.
    The 192.168.x.x IP range is for 255.255.255.x subnets, which are very small.
    The "255.255.255.0" subnet means is that the iPod is not allowed to talk directly to the Ion, as the first three octets don't match.
    - It's even worse because the Ion can't get to its Default Gateway, so it can't even as for a route.
    So at the moment, you're running on luck.
    - We multicast the essential stuff, but you'll find that you can't actually Ping across this network.
    When you have some time, I strongly recommend changing the IPs to the ETC standard set, as in the Wiki and in the link given earlier in the thread.
    We use 10.101.x.x and 255.255.0.0 to give a large subnet and allow everything to talk directly to each other.
    - Don't use anything else unless you're a networking guru, or have been assigned the numbers by one!
    For a small system, I recommend the following:
    On the WAP, turn DHCP off completely.
    IPs:
    • WAP: 10.101.15.101
    • Ion: 10.101.90.101 (factory default)
    • Managed switch: 10.101.1.1 (if you have one)
    Default Gateway: 10.101.1.1 on everything
    Subnet: 255.255.0.0 on everything
    Now, in the Ion turn on Network Services and the DHCP Server, with it's default of the first IP 10.101.50.101
    - There must only be one device with the DHCP server turned on, so only do this in one console!
    Your iPod will then ask the Ion for an IP when it connects to the WAP, and will get 10.101.50.x
    The iRFR app is then set for 10.101.90.101
    This also has the benefit that getting a laptop to work (eg for Mirror mode or Client) just requires that you plug it in.
  • I have to admit I'm new to networking.  I made the changes as described for the ION.  I turned on it Network Services and set the start IP to 10.101.50.101
    The WAP I'm using has a DHCP client option, which let's it get it's configuration from the ION.  So I let it do that.  It keep requiring me to set in the DNS pathways along with IP and Subnet.  I didn't know what to enter manually, but the option to set itself up from the ION's DHCP is working.
    I connected to the WAP with my iPod and let the choose DHCP.  The ION served up the same subnet mask and IP as the Network Service put out.
    The ION is set to 10.101.90.101 and so is the iRFR.  It works faster now.
    Thanks.
  • Excellent, glad to hear it's all working fast now.
    We have the defaults and the Network Services so that you don't need to be a network guru - you've got better things to worry about than trying to pick IPs!
    Don't worry about the DNS stuff - we don't use it.
    [edited by: Richard at 1:08 AM (GMT -6) on Wed, Oct 6 2010]
