Tracking / CueOnly
If you`re ure usually working in Cue Only, as we do `cause in some productions none of the cue`s stays as it was originally programmed. So it woudn`t be usefull if every correcture would be tracked automatically. Of course it`s very usefull being able to track single intensities, colors or positions manual. But I hate to be that carefull using that button.
An operator I`m working with had the problem that he switched to tracking-mode accidently and didn`t notice instantly and that meant a lot of Undo.
So, in my opinion the posibility to switch from cue only to tracking mode has nothing to do there! Keep it in setup as it is if you wan`t to change from tracking to CueOnly.
[edited by: Paule at 12:04 PM (GMT -6) on Sun, Jan 8 2012]
