Can I get an updated profile for the SGM G Spot Extended, and the GSpot Turbo Extended Comp?
The profile in the desk is a bit off.
Thanks.
Mark
SGM_G_Spot_DMX_Chart_REV_16.pdfDMX+Protocol_G-Spot_Turbo_Rev_2 (1).pdf
Could you detail the issues that you are seeing? What exactly is off and needs to be adjusted?
https://www.dropbox.com/s/43jjr75u0e1ucgw/gspot%20comparison.docx?dl=0
Here is a link to a word doc that has snapshots of the changes I made in the profile to get it to work correctly. Modified profile followed by library profile.
Some of the main problems are the strobe defaults to closed, and the animation wheel defaults to inserted and spinning.
I'm also trying to get a fixture that will work with Augment3d. I tried to just duplicate the changes in the new profile and that just seemed to break the augment3d model.
Also here is a link to the show file that has them.
https://www.dropbox.com/s/eown2s617533mj1/HA%20Breath%20of%20Life%202020%20-%20v4%202020-12-18%2023-29-33.esf3d?dl=0
Thank you for the information, request submitted!
The team has found the following while comparing the provided profiles and would like to confirm those are the changes you are looking for:
Requested changes:
Shutter Strobe from the manual either default “Open” is correct
