Artfox Sky Beam 9R
The Artfox Sky Beam 9R already exists in the EOS Library but the 'Lamp Off' function does not work.  I access 'Lamp Off' from the 'Lamp Controls' section which comes up after I push the 'About' button.
I'm using these on an EOS Classic. I upgraded the EOS to 2.9.3 today and updated the fixture profile in Patch and tried it again today, no luck.
I've tried this in the past from an ION Xe20 and it didn't work then either.  that was probably a few years ago.
Can this be made to work?  A link to the manual is here: https://www.artfox.net/res/manual/Sky%20Beam%209R.pdf
Thank you,  Ken Heaton
