I have had this issue 2 days in a row now on startup and am very confused...
H3
Exp. Wing
Playback Wing
DP8000
DP2000 (Artnet Mode)
Console upon startup goes through setup and, when finished booting, triggers startup macro without problem.  However, there is no console output.
I open the DP8000 window and go to settings and all of the Artnet Settings are reset of default and OFF.
This has happened twice now.  Standard shutdown procedures are followed everyday.  Yesterday when it happened, the console had been off since Thursday.  Today, the console was only off overnight.  The DP8000 and DP2000 are not shutdown.
Could this be a fault of a BIOS battery going bad?
