Wifi Hog3PC and iPC on 3.2 issue
I open a new Thread, becouse i dont get Wifi (RFU) running...here is the old Thread:
(i connected iPC 3.2. and Hog3PC 3.2. as i usually did all the time before
3.2 HogPC as RFU ...it takes much longer to connect to iPC Show, but i can launch...after a while (different, some minutes ) and some button action Hog3PC crashes, in Networkwindow on iPC i can see that the PC node is alternating to offline/online before it crashes...
There is no difference if i use same or other Netnumber, IPC is Server.
i did not change any configurations in my Network prefs (Firewall off)
Hog3PC runs on XP SP2, Apple Airport Express
Never had any issues before...
Any Hints?
Marc
It works hardwired , no crash since 30min ,..is it possible that it is a Wifi issue with 3.2? The config of Airport has not changed since 3.1.9)
The connection is very unstable via Wifi and Hog3 PC crash after a few minutes. Its stable and work with Cable!
Marc
