Cyberlight Power
Hey Everybody,
I recently gotten a few used cyberlights, I've used cybers before, but i've never been responsible for actually connecting power. So..
being a novice (but one who catches on quickly) i want to make sure i power my cybers correctly to test them, and eventually use them.
I was reading the manual, i see i can choose what power i want to use by moving the voltage wire within the fixture, my question is, the manual states i can use 208v (which i assume means i need 3phase), or i can use 230v.
In this venue i only have access to single (split) phase, so 240v. Is that the same as 230v? if i power the cybers with single phase 240v will i be safe, as long as i have the power connected correctly in the fixture..
Thanks much!
