One last question about this X-Spot
Okay guys, so where is the FCS motor located?
So far in this unit I have had a CTB control tab loose that I had to rewire, I had to reassemble and reseat the litho assembly (it was in backwards), I had to loosen the magenta flag and clean the sensor, and I have replaced two motors (from the litho assembly, the rotation motors).
This is the last thing on this blasted unit.
Mike
