Hello,
Does anyone know why is it with the latest CEM+ version 3.1.3.9.0.44 has error message on display says to update version? Another rack with older version 2.1.0.9.0.24 has no error message. Thank you.
Hello,
Yes, this is something that can happen. It’s not uncommon for one rack to report a version mismatch while another does not. There are a few different reasons why this might occur depending on how the system is networked and how the racks were updated.
A few quick questions to help narrow it down:
If everything is functioning as expected, this is likely just an annoyance rather than a critical issue.
When you’re ready to resolve it, you can update the older 2.x CEM+ to match the newer version. This ETC Support article walks through the process step-by-step:
How to update software on a CEM+ module
And of course, if you’d prefer direct assistance, ETC Technical Services is available at 800‑688‑4116.
How to clear the error? Thank you.
You would definitely need to do what I recommended above based on your answers.
You can update the older 2.x CEM+ to match the newer version. This ETC Support article walks through the process step-by-step:
ETC Technical Services US is available at 800‑688‑4116.
If you are in a different location, see this link: https://www.etcconnect.com/Contact-Us.aspx
