The facilities director switched the house lights to the led version of par 38 bulbs, if I buy evl10 dimmers will that fix my issue with blinking bulbs?
Benjamin, are you with Covenant Life Church in Grand Haven?
 If so, our records for job number 108780 suggest you have a 120v original Sensor CEM (aka "Classic") rack system.
 Unless your rack has been upgraded to a CEM+ running recent code or to a CEM3, I'm afraid ELV modules are incompatible with your system.
 If compatibility testing (info above) suggests ELVs will work better for your loads, that upgrade is something you could get quoted from a local dealer.
