HyperDeck Ethernet Protocol (TCP) - Sending from EOS.
Hi All, Looking at trying to start and stop a Blackmagic Hyperdeck Recorder.
Problem is it seems to only use TCP. Is there any way to send a TCP Command using HyperDeck Ethernet Protocol (TCP) to this without adding another piece of hardware in between.
I have looked into adding a ESP device on the network to be a translation hub.
Just trying to figure out an easy way to set the recorder to record on Q1 and end of last Q of show - without having to physically push record.
Or is there any roadmap to send TCP messages like the UDP from within EOS?
Cheers.
