Hey there,
I am installing a few new fixtures (in the subject line) and want to know if there is a generic fixture in the library I can use? Would it be easiest to use the Venue in 3 channel or 7 channel mode?
Thanks for the help.
Hey there,
A quick look at the manual indicates that it is very close to the existing "PAR 38" in the library. So, you could patch it as Generic RGB LED 8B and run it in 3-channel mode, or copy and edit the PAR 38 personality to add a dimmer channel (and possibly some other small changes) and run it in 7-channel mode.
Because the Eos/Gio/Ion software has a lot of control over colour/intensity, etcetera - you probably won't find much advantage in the 7-channel mode, to be honest.
Luke
Thanks! That worked like a charm. I assume I can use the same generic profile for the Venue Thinpar too? I am going to try it tomorrow (I don't have the right DMX cable for the ficxture).
have you tried creating a fixture using fixture editor?
I mean our DMX splitter. I thout about the universe thing too, but I have some chauvet colorstrips running off the on stage DMX splitter that work just fine. They are on universe 1 (address is 200) so I am not sure what the issue is.
I realized that it is not the profile since it works FOH but not on stage.
try first principle. check Cables and connections might be just a bad cable on stage
Thanks, I tried at least 5 cables as well as the know good cable from my working colorstrips.
Did the cable option Work?
No, it's not the cable. The known good one didn't worth either. I am thinking it might be a universe thing.
if its not cables, then its either a universe or addressing issue. remember that patching fixtures on each universe above the first one, need to be written 2/DMX Address, 3/DMX address and so on. Or second universe starts at 513 to 1024. 3rd universe starts at 1025. if your address of your fixtures are starting at 200, and they are on a second universe then you need to patch as 2/200 and so on.
So back to cables.....is the stage locations wired to a second universe.
Thanks for the suggestions. I am not on site today, but now that I think about it, I mounted a couple big movers a month ago and they are on universe 2. They worked perfectly and they are using the DMX splitter on stage.
my question is, the fixtures I am trying to add say they are only addressable up to 512. If they need to be on universe 2, how can that work?
