If you discover an issue with an existing fixture profile, please let us know here. We will investigate and correct if necessary.
Thanks much!
Anne
Thanks much!
Anne
Hi Sasha,
Thank you for your reply. Whilst I am aware of the HS fade downside, I never enable it. I like to know that I am not fading thru green. [;)]
Also, the way I look at it, one is not controlling individual cells, you are controlling multiple parts of a fixture, like for example the Mac Aura. Denying access to those features of a fixture might be a bit irritating for the less experienced user, ( not knowing how to enable ( edit) a fixture template), or somebody who got those fixtures just for the ability to have three different rings of colour.....
Just my 2p
Hello, David:
How did you determine that the rate is slower?
The output range should be 0-33Hz, which is determined as follows;
The on pulse is always 10ms. The shortest off is 20ms. The total period of that range is 30mz, so one time in 30mz is 33Hz.
Thank you,
In the Vello Lighting Noble Gene280 profile, the supplied Color Wheels don't show up in the ML Controls or on the Encoder LCD screen. It acts the same on the Nomad software.
I've tried creating custom color & gobo wheels for the device and the images don't show up on the ML Controls or Encoder screen.
I'm running the newest (2.2.1.9.0.13) firmware & latest fixture library (Build 53).
Jeff
Hello, Jeff:
I am sorry that you are having issue with our profile for the Vello Lighting Noble Gene280.
I have not been able to duplicate the issue on either Nomad or Eos Ti for color swatches- they appear in both ML controls and the encoder LCD.
Would you mind trying to install a fresh download of the library patch?
Are you seeing this issue with any other fixtures?
Thank you,
