Variable in Step Based Cue Help
So, at LDI I had a detailed conversation about using variables in cues that would run in the cue time. Am I missing a part of the process?
Build:
Step based cue, simple repeating chase, add for example Var 1 and Var 2 in On State and Decay.
Set Var 1 at 100 and Var 2 and 0
Record the effect into Cue 1 and Cue 2, both with fade times.
Goto Cue 2 - edit Var 1 to 50 and Var 2 to 30, update
Expected result: over the timing of Cue 2, On State fades from Full to 50, Decay fades from 0 to 30. The rest of the effect runs continuously.
Actual result: Cue 2 will restart the effect, from the first step, interrupting the chase rhythm.
File attached showing a version of this idea, but with the same result.
Any ideas?
RickEffect w Var 2024-02-03 11-48-16.esf2
