Hi team,
I have a bunch of moving heads which, when loaded into A3D and put in to a FP do reflect real space or the other way around.
Example MH6 in FP that is in an XX formation on stage. has the fixtures pointing all over the place, or if I set in a FP in the real space sent the positions in all random directions.
What I have done is set the XYZ axis in the setting line at 0,0,0. Then set the lighting bars at the correct Y and Z values (measured) and then the X values -x thru x at the measured positions.
I even tried to do FPE but that failed so badly I had to laugh. I have tried rotating the fixtures in A3D and they look good for one FP but then for the others not good at all.
Fixtures are: Chauvet R1 Spot, Martin Rush MH6 and Martin rush MH7 (these seem to be not far out).
What can I do about or have I missed something?
I work in another venue that has EK K smart, Clay Packy Axcor 300 and Silverstar Pluto2000's and they appear to be 95% accurate.
