Problem with strobe
Okay this probably has a simple solution, and Im just not seeing something.
I have a template page with a pretty standard strobe cue of Int=100 Rate=10hz Length=0
when I try to make a separate cue with max length (for a blinding look), it changes the first cue to the same settings. Even if the new cue is released.
And then if I delete the new cue, the original cue only blinks the strobe once, but after a while goes back to what was originally programmed...
Im using a Road Hog FB with pretty new softawre and the strobes are Martin Atomics in mode 4.
Thanks for the help!
