Is there any difference in using the built in cameras on a DL3 then the cameras on a DL2?
Is the principle the same that you run the s-video/SDI input back and reroute the signal to the correct fixture? Am i correct in saying i can now use the SDi to send/return the camera signal??
Is the d-tec pro switcher still the correct equipment to spec for this setup or are there alternatives?
Anything different to look out for when setting this up on DL3 fixtures?
Again anyone who has used this setup will be at an advantage in explaining it to me.
Thanks Cormac
