Upon Bootup, the ION Reports a CMOS Battery Failure.
Any thoughts? Is this something that can be replaced easily?
Does the ION need to be sent off to ETC to repair?
It's pretty easy to replace the battery in there. The battery you'll need is CR2032.
Follow the steps in this support post for instructions on opening up your console:
https://support.etcconnect.com/ETC/Consoles/Eos_Family/Ion/How_to_Open_an_Ion
Faced the same issue. Talked to one guy, and he said that I could try replacing the battery. The only question left on the table is which one to get if the original one is out of stock everywhere?
The CR2032 battery is super common and can be purchased almost anywhere (even in my local grocery store). Are you concerned about brand? Any major brand (i.e. Duracell, Energizer) will be fine.
