Multipart Cues
What are the benefits of a multipart cue as opposed to two or more normal cues carrying out the same functions?
Going back to an earlier post asking how to zero ML intensity while moving but restore on stop. Would a multipart cue be more suitable?
  • My apologies. Looked up my last post and thought perhaps an actual application might help.
    Here X and 0 are regular dimmers. FP and INT refer to a single ML
    Want to achieve
    Cue 1;   X X O O X X FP1 INT:100%
    Cue 2;   X O O O O X FP2 INT:100%   Note the change in focus
    Under normal conditions one would see the beam sweep to its new position. But I don't want that.
    So, leaving Cue1 alone could I take Cue2 and split it into a multipart cue like this;
    Cue 2.1;                                   INT:0%    Make this part last only long enough for the focus to complete.
    Cue 2.2;   X O O O O X FP2 INT:100%
  • This looks very similar to the post below, and I think will help guide you in making the distinction between part cues and follow cues:
    https://community.etcconnect.com/control_consoles/f/eos-family/32509/part-cues
    Essentially, you want to create a follow cue to accomplish what you’re trying to achieve in the example. Multipart cues are mainly helpful for two things: having a single cue that does many things at the same time, but with different timing (eg, area light change on a time 3/5 while the cyc moves at a time 30); and for organizing information (eg, marking in part 20, or putting the fixtures that are on a custom curve into part 3).
  • Wuz - any chance you could make this two picutres is there? I'm having trouble reading the smaller text. From what I can see this looks like a Multipart cue and I'd like to see the detials to compare with the Follow cue idea from Cody.
  • Don't worry about new pics - I managed to read it and put it in a spreadsheet for my desk notes.
    This is what I think I see happening;
    Cue 1 is a regular cue with some dimmers set and our ML Int at 60 with a focus set by CT (Is that a FP?)
    Cue 2 last 5 seconds and sets up a 'Forward' F2.6. Is this 2.6 secs or ref to a cue 2.6?
    P1 of 2 Apart from some dimmer changes we see our ML go to zero and the focus changes to TB
    P2 of 2 Say the Movers fade out. But didn't this happen above?
    P3 of 2 Now the movers move! Again see P1.
    2.1 in this new cue (nothing to do with cue 2 above) the ML's intensity is set back up.
    But - if the Fw/Hg F2.6 was ref to a cue 2.6 this would jump 2.1?
    I suspect this is not perhaps the way things were entered but merely the way the spread sheet is showing us what happens. Clearly I have to learn how to plug this stuff in and get down to some serious reading here.
  • Click on image. Right click. Select "View image". . . . That will make it full screen w/ zoom.
    In a multipart Q, grey items change in a different Part.
    Q2 P1
    • Channels: 31 + 36 + 51 + 56 + 411
    • fades the conventionals in 5 seconds.
    • No action on the moving lights in this Part.
    Q2 P2
    • Channels: 601 - Intensity
    • Fades the movers to 0 in 2.4 seconds
    Q2 P3
    • Channels: 601 - Focus + Colour + Beam
    • Delays 2.6 seconds so the movers can fade out in Q2P2.    (should be 2.4 seconds)
    • Focus, Colour, and Beam move in 0 seconds.
    Q2.1
    • Auto-follows Q2
    • Fades in movers in 2.4 seconds
    Total time to complete Q2 + Q2.1 = 5.0 seconds.
    Does that help?
  • Oh yes it does, indeed.Thank you for going to all that trouble. All cut'n pasted into my notes, Today I was able to record a simple Follow, a Hang and a simple Multipart so the bits are coming together. With your notes I reckon I should have this  under control very soon now.
  • In Q2 P2 how was that delay of 2.6 and then the moves are to occur in 0 secs made? I'm finding a lot on Delay but mainly for Fanning where an incremental delay occurs. Still can't see where/how we say, once delay is complete then execute in 0 time.
  • Delay and Time are hard keys right next to the Shift key. You can apply both of them to a cue, or a part of a cue, or to specific channels/parameters for discrete timing. Syntax here would be Cue 2 Part 3 Delay 2.6 Time 0, though the order of applying a delay or a time to a cue doesn’t matter, and they can also be separate commands.
  • I've used the 'Time' before but wasn't sure how to wrap up it and the delay. Or if the zero execute meant cue time. I left early today to settle in for a good session to crack this stuff. We received 6 MLs this am. 4 of them have problems with their menus!!!
  • Cody. I spent hours and finally got a blind spreadsheet to look just like yours. But when I tried to reprodue it things went downhill! I am not sure of the order of things. After writing a start cue Q1 do I then make the End Result cue Q2.1 and then select parts of it to go into MPQ2 parts? I'm sure this is one of those things when  I get it I'm going ot wonder how I made it so diffiult.
    Interestigly I was in the booth this am with a very smart guy who is new to the board and he observed the ML moving between cues and asked me how to get rid of it,. When I told him a needed a MPQ and a Follow he commented that as this seemed a pretty common task (turn off light, move, turn on light) he was surprised there was not a much simpler way to do it. I actually dread having to go thorugh all this with the guys who will be putting the cues in place for the show.
  • you don't *need* part cues to do this. you can have cues 1, 2 and 3. cue 1: ML is on on position A, cue 2: ML is off (fades to 0 while still on position A), cue 3: fades in on position B. to make the ML pre-position automatically you can use the automark function of the console.
    the parts come into play when you want to manage timing because the ML that needs to be faded out to re-position should fade out faster than the rest of the cue. as someone else has mentioned parts are a way for data managment. you can use them, you most certainly don't need to use them. neither do you have to use the follow. of yourse you can manually press Go
  • Oh lordy this does seem easier at least for real novices. If I remember right, to 'keep' the ML at its old position (from Q1) as I go into Q2 I use the [AT] (to stop autmark).
  • I made those three cues. Much easier to understand. Looking a my blind sheet cue 2 which fades the ML is showing MK in green  (Mark). The P&T etc though show Q3 in green - what is this.
    The Auto mark should set up the focus to the next postion only when the intensity is moving away from zero - so I don't need to do the [AT] {out] [Update] right?
  • green MK: green = intensity value that's lower than in the cue before. in your case it's like a green 0. MK = as soon as then intensity hits 0 the console willl mark the fixture.
    automark happens when you press Go for the cue before the intensity goes up (if the fixture already had been at 0), or if the fixture is only fading out in the previous cue, the automark will happen when the Go has completed
    this wouldn't work. after all you want to the fixtures to fade up when you press go, and not wait for the automark to complete
