How to run a DP8000 on a HOG IPC?
In my setup I run HOG 3PC V 3.0.5
There are running 2 DP2000 (these are running perfectly)
I’ve recently linkt up a DP8000, and want to test this device.
The DP8000 was running V3.0.0, I forced the DP8000 to load the V3.0.5 software by pressing the 3 buttons at once while powering the device.
This works perfect.
The DP8000 is running V3.0.5 (shown in the control panel Hog 3V3.0.5(b2482))
The DP8000 loads the new software but I don’t can get it running.
The display on the DP8000 shows: Connecting, No server, scanning port 6600.
4
The LED near Hog-Net Link is flashing
On the back of the DP8000 the Link LED is on, and the Traffic LED is flashing. (Hog-Net Gigabit – Ethernet)
My setup: HOG IPC (internal DP8000 NR1 IP: 172 031 000 001)
WAGNER TOOLS SWITCH
-DP2000 (NR 2 IP: 169 254 128 099)
-DP2000 (NR 3 IP: 169 254 128 003)
-DP8000 (NR 4 IP: 169 254 128 007)
The IPC is set in the network section as use defult IP settings.
Do I forget something?
