Is there a way to fade out a chase, or some endless linked follow-cues, running in an other cue-list than the active chooser using a macro command. So the chase is still running, and fading out. The macro should give the fade out-time. To mine opinion the syntax would be, for example: FM8/0t10, this is not working, M8 fades in 0s. to 0. I am only allowed to do this with RM8t10, but then there is a halt at the cue that was running in the chase and M8 releases in the given time. But I want to see the chase slowly fading out. Does anyone know a solution?
sander
